well finally tried it in the water yesterday, not to good.. I have a 1882 johnson 140 hp on a 19' baja I am new to boats and boating . I just got this set-up and joined the forum and with help got it running pretty good on the trailer.. I have done the fuel system removed tank , drained and cleaned all new lines to the fuel pump that I removed and rebuilt also did a waterpump and thermostats along with plugs removed carb and cleaned them seemed pretty clean .. My problem was I took it down to the bay off trailer started it warmed it up put it to idle position and it would want to stall if you put it in gear stall right away.. On the trailer you can put it in gear no problem , I could not force it into gear due to the safety on the warm up lever, put it back on trailer and on the muffs and you can put it in gear, seems to run pretty good but my buddy stopped by who has a boat and says the carbs
need to be rebuilt, looked for info in the search of the top secret explains rebuilding carb`s but is that my problem?? not sure where to go from here.. Thanks in advance Bill
