help needed Thunderbolt V ignition timming
chamm63
HI ALL
I HAVE A 1996 Mercruiser 5.7l Alpha
THAT I HAD TO PUT A NEW ICM Module Conversion Kit
IN AND WANTED TO KNOW
HOW DO YOU SET THE BASE TIMING ON IT AND WHAT DO SET IT AT?
THANKS CHUCK
Re: help needed Thunderbolt V ignition timming
HI ALL
THANKS CHUCK
Ayuh,.... Welcome Aboard Chuck,.... No reason to be YELLIN' at Us,....
Got a serial number for this motor,..??
Don S
8? BTDC at idle rpm is what you set the timing at.
here are the instructions for setting the TB5 timing.
