I have a 1998 30 hp Johnson motor. I was taking off the lower unit and when I disconnected the water pump I noticed that the gasket was cracked and flaking off. Should I replace the gasket or get a whole new water pump. Also after I put it back together and when I turn the propeller by hand I can hear the pump rubbing on the drive shaft. What should I do????????????????????????????????<br /><br />Thanks<br /><br /> Nick
