Striper Rig
- Joined
- Jul 20, 2009
- 40
I have been working on a Mercury 175 v6 1977 ob...
I had to put head gasket on the left side of the motor, because it was blown at # two cly...Fixed problem...
I also put a head gasket on the right side...
I thought I was getting water in the #3 cyl, but I found out a little while ago that the motor is not getting fire on the #3 cyl, on the right side...
So I checked all fire on plugs and found I was not getting fire on the #6 cyl also...on the left side of the motor....
The rest of plugs are firing blue sparks when I checked them....
Plugs and coil wires are ok...
What do I need to check next with no fire on #3 + #6 cyl's...?
