I inherited a 1973 Larson Shark 1650 with a 1973 Evinrude 115 hp motor. The history involves the original 125 Evinrude motor with power trim removed and this one mounted on it. I have repaired items as they have been found. The starter, solenoid, fuel tank, fuel lines, Teleflex helm to engine steering system, decarbed the engine and it now runs great on the muffs. I have taken it out and I am having trouble getting on plane. I have moved the thrust pin out and it just brings the bow up further. By reading these forums I believe I need to raise the motor without moving the motor back. The motor rests directly on the transom cap and I do have about an 1-1/2 " but I need more to get cav plate even with the keel. Does anyone have a good recomendation for a lift plate that does not move the motor back or at least minimally?
Thanks for having these forums to help the first timers.
