I'm abut to install a rebuilt powerhead, so I went ahead and soaked the carbs and am currently in the process of rebuilding them using the proper kits.
I stumbled upon two problems:
1) The two screws that go into the face of a carb had these thick o-rings, the kit came with a red plastic replacement for this o-ring. The problem is that I'm having a problem getting the screw face to be flush with the carb surface. I've torqued the screw pretty tight. Do I need to take the o-ring out and trim it?
2) How do you secure the new plug (or whatever its called, it looks like a dime)? Does it take a special tool to hammer it in place. It looks like some kind of a die or stamp is used to tap the top of the plug so it spreads out agains the inner rim of the hole, therby securing it.
I've atempted to post pics, any help is appreciated.
