help on prop selection
hello I have a 1990 four winds 190 freedom right now i have a 14.25 X 21 rapture stainless steel prop. However it feels sluggish when coming out of the hole when trying to pull skiers. I think i should go down to a 14.25 X 19 would this be a good prop for better out f the hole speed? how much top end will i lose? any suggestions thanks
countvlad
Re: help on prop selection
what is your current WOT RPMS? also a 4 blade will help you a lot out of hole and puling skiers....
junior1113
had a 93 180 horizon with a 140 evinrude great boat. 13.75x 21p=46 mph@ 5500 rpms. agree 4 blade is more effiecent. what kind of motor and wot rpms
sorry im new to boating its my first boat..What does WOT stand for? I will have to check my rpms when im maxed out i know with about 4 people on the boat i get up to 46 mph im im thinking its about 5500 rpms but not 100% sure. I have a omc cobra engine 190hp.
gostephen
WOT= Wide Open Throttle.
i prefer a 4 blade prop when pulling skiers/tubes i get a better hole shot and better control when making tight turns at speed.
So based off my motor what size of a four blade prop would you recommend? any particular brand?
junior1113
double check wide open throttle (wot) rpms. 5500 is on the high side for an omc inboard should be more like 4400-4600.
ok i checked it two ways with the WOT.
1st way was WOT the trim all the way down i got up to 32mph at 3500 rpms
2nd way was WOT the trim was half got up to 42mph at 4500 rpms
any suggestions??
hwsiii
What exact motor do you have on that boat.
H
hwsiii
JD, if I have the right gear ratio for your setup 1.61:1, please verify this. If this is so then by changing to a 19" Solas Amita 4 blade prop you should increase your RPM slightly and gain a lot of hole shot and acceleration with less bow lift and maybe lose 2 MPH. They are only about $ 120 here on Iboats.
H
Yachtsman1304
I went from a Michigan Wheel 3 blade stainless 19" pitch (48-78120-19) to an aluminium Solas Amita 4 blade 19" pitch (1513-48-19) and totally love it. I am running a 1997 Merc. Alpha 1 Gen II, 190 HP.
I cannot say enough good things about the Solas prop. Extremely high quality and great price.
Well sorry this took so long but since t was the end of the season I didn't try out a new prop however For this season I did take your advice and I dropped don a size and bought a 14.25 X 19 Hustler 3 blade prop, I have heard great things about this prop and a buddy of mine has it and only has good things to say about it. Hopefully it will warm up soon so I can start going boating and I will let ya know how the new prop goes!!!
