Help ON Timing 4.3 merc
Amy-Lynn
Hello maybe someone can help. I have a 4.3 1990 mercruiser and just replaced the head gaskets and all done but timing i disturbered the piston so i put number one at TDC and put the roter inline with number one wire on cap .. My experiance it should start Can anyone tell me if im doing anything wrong on that end but i think it should start and time it from there..Any help would be graet thanks
Re: Help ON Timing 4.3 merc
Ayuh,... My WAGuess is,.. You're off by 180?....
Did you verify TDC at the valves,..??
If Not,.. Rotate the crank 360?,+ reset the distributer,... Then it'll Light....
180shabah
If you are truly at TDC on the compression stroke then yes it should be able to start., As mentioned above though, if you are one revolution off, then the plugs are firing on the exhaust stroke, so no it will not run.
Amy-Lynn
Well just to let everyone no that i did indeed get it i had few valves to tight. I couldnt find my oringinal post i thought it would email me when someone posted a comment but i had to search for my post ...Anyway motor runs good till i took it out and she cut out after a few secs of being on plain back out of it and she runs good so anouther problem to work on .. and if someone can email me and let me no how to set this up so it notifys me when someone post something taht would be great thanks all
Ayuh,... She's Starving for Fuel,...
Start with the fuel filters, they're easy,....Inspect their Contents for water, or other Crap...
I don't know if iboats has email notifications or not,...
You should find it in your User Control Panel... portside of the Blue band, near the top of every page...;)
