DaveAF
- Joined
- Feb 25, 2008
- 39
Still trying to get the 88 50hp Evinrude running right (E50BECCS)
Today I went out to the marina and want to do some more trouble shooting. So using the OEM manual and a vohm meter want to check the electric coponents.
The coils are new, the power pack is new. So now I am trouble shooting the sensor coil and the charge coil. Both are with in specifications for resitance. I really could get a good reading when I tried to test the out put.
After I finally get the engine to start and run I started back to the basics. I pulled the plug wires starting on the bottom cylinder. Nothing happened it kept running. Pulled the top cylinder and the engine died. I swapped the spark plug wired and the the same, so I figured the plug wires are good. I then swapped the coils and the same.
What controls the time the coils fire? is it the power pack? or one of the sensors under the flywheel
Also if I have to pull the flywheel off, what is the best advice for breaking the center nut. I have a harmonic balancer and I am getting the Grade 8 bolts. I just cant figure out how to hold the flywheel while I loosen the nut.
I am needing help
I am needing help
