Ok. here goes. I cannot figure out which fuel pump to order. The first two pix are the old fuel pump. The next are the choices for it. It looks like the V6 pump is correct, however, they are telling me the other one. Problem is the other one doesn't have the same connection locations so I'd have to get new aluminum tubes. HELP!
Here's the info:
Engine:
OMC Cobra GM 504APRGD carbuerated 4 barrel
The fuel pump in the first two pix has the following on it:
Carter
flange say 0-2208
There is also a 7K288
Here's the info:
Engine:
Carter
flange say 0-2208
