My 2003 Trophy is overheating. I am hose testing this in my driveway as I just purchased this boat. She overheats at idle or in gear. This is a dry joint system. Also there is no water exiting the exhaust after reaching operating temperature. This is what I have done to date.
Check impeller. Looked fine/ Replaced anyway including tube o-rings etc.
Checked t-stat. Passed boiling water test/Replaced anyway. While I had the t-stat hsg. off, I checked the spring loaded check valve ball assy which seemed to move freely.
Removed starboard side manifold, spacer, and elbow. Water flow tested for obstructions./ None noted. Checked flapper operation./ Seems fine. Water flow tested with garden hose for obstructions./ None noted.
I am getting ready to remove the port side manifold today. I also check the spark plugs for water and found none. Compression also good. The motor seems to be running fine. Am I missing something simple here? Overheat issues on the dry-joint system are hard to find.
