No, it's plastic. Tap a short bit of a wide screwdriver in there a force it out. Go easy because there is not much depth and the exhaust cover is aluminum.
Heat up a screw driver blade and force it in the hole (melt the plastic) let cool and twist it out.
If that fails, drill out the plastic and run a tap in the hole to clean it out for the new fitting.
