my service man. says to adj. THROTTLE CAM LINK to 53mm but doesnt tell from what point.(end to end)or(center hole to center hole) and how do i tell if its a (e115a)(c115tr)or all outher it says 115tlrb bellow 6e5 L 1004362 FAMILY 3YMXM1.731CA
My boat wont idle if i set to specs(good compression) (clean carbs) specs are idle 4-6 atdc i have to set it at 4 btdc then it idles and starts pretty good but when i accelerate to fast it bogs out and at trooling it sounds a little rough and might die if i troll 1/2 mile wide open says 24-26 btdc i have it at 28btdc the only thing im thinking is the throttle cam link might be wrong
