Re: HELP PLEASE 1972 evinrude 85hp outboard
Pillatzki.... You say you can pump the fuel primer bulb until your hand gets tired. I assume that this means that the primer bulb never gets hard. If so, install another fuel primer bulb and have the arrow (fuel flow direction) on the bulb facing the engine. Hold the bulb vertical (arrow up) when pumping.<br /><br />You also say that if you prime the engine at the carburetor(s) the engine will start and run until you shut it off. I, again, assume that you mean shutting the engine off by turning the key off, and that the engine will run for whatever length of time you desire before shutting it off.<br /><br />If this is the case, I would suspect that either you are not operating the choke when attempting to start the engine, or that the choke is not functioning at all when you engage the choke switch.
