fishhead24
- Joined
- Apr 4, 2004
- 19
I have a 1985 50 HP 4 cyl Mercury. Serial A100677. I just got it running last week after having to replace stator, trigger, and switchbox due to wire rot! It ran great, I ran it most of the day last Saturday with no problems at all! I took it out today and it ran fine and then while running at about 3/4 throttle , the rpm's skyrocketed, like it went into neutral. It will move in forward gear at idle and a little over idle speed. When I throttle up it stops pulling and races up! I thought maybe the prop had spun, but after checking it , It seems ok. When the motor is in forward gear I can turn the prop by hand easily in the forward rotation direction, it does make a light clunk every rotation. It will not turn in reverse direction. When in reverse gear I cannot turn prop either direction. When running it does ok in reverse. It does not make any odd noises at all while . running.Any help would be greatly appreciated. Thanks in advance. The more I think about it the more I suspect that it is a spun prop hub.I tried to turn the prop to see if it would move on hub, but couldnt budge it!
