This one is a bit tricky, I have a 91 johnson 200 and for some reason when I trim the engine while the motor is running, i keep blowing the main 20 amp fuse to the engine losing all power to my gauges and trim, becoming a bit dangerous, trim wont blow fuse if motor is not running and works fine.... I would appreciate any helpsomeone might have Dan P Stuart, Fl
