I just bought a boat with a early 70's johnson 20hp motor took it out and idles great runs at low speeds great but once you give it gas it stays running but barely moves, i took it to a boat mechanic and had a compression test and over 100psi in both cylinders also had carb cleaned and fluids changed??? if anyone can help it would be greatly appreciated i really want to get it working
