Help please
Steve 167
1976 Starcraft tri hull. Volvo motor. Thinking about buying this from a friend for probably right around $900. Has not run in a couple years. I do not know a lot about boats, but am pretty good on mechanical. Thoughts? 01C8A03F-F49C-4D24-A933-E7364A05F481.jpegA2808C46-119D-4CA5-A6AF-9BFD162DCD2A.jpeg5DBF0720-8AB4-4B87-8392-68A4857FB106.jpegB83A59F1-317F-4F8D-A708-B52EAE14E499.jpegC7FBC46C-6F37-449E-A401-6B63B1BACBA6.jpeg
Ayuh,..... Welcome Aboard,......
The issue I see is,.... The motor is obsolete, 'n gettin' tough to get parts for,.....
lprizman
If you can drive down the highway and throw $3K out the window and still smile....do it.
Boat Cost + battery + estimated cost to get running = $3K roughly
Boat in great running condition on trailer turn key is worth $2,500.00
A friend does not sell **** like that to a friend......
lprizman
Yup...not trying to be a downer...just advice.
Put a battery in it...fresh alternate fuel source...see if she fires....then sea trial after a good structural inspection and verify bilge pump works and plug is in...give it a go!!
Best of luck!!
Let us know how you do....maybe be great...which I'm hoping for!
Lou C
Boat looks to be in good shape. As noted the issue is parts availability and the difficulty in converting it over to a modern drivetrain (Old style Volvo, large transom cut out, won't take a modern drive system without fiberglass work). Check it all over for rot, if you find rot forget it. Really!
PS I think I see silicone around the transom mount, that means only a few things, leaks, rotted transom, etc. Proceed with caution, lest you wind up in the restoration forum asking questions.
jerryjerry05
The Volvo is the BEST drive out there.
Your Volvo is a good one but VERY expensive to fix.
One test: walk past the drive and push it to the left and right.
If it travels more than 1/4-1/2 in. That repair can cost 1-2K
I love Volvo's had 4 but I wouldn't buy one that old.
Good luck.
Get a newer model at least a 94 and up or get a Mercruiser
and ABSOLUTELY stay away from Cobra and old OMC
