help pls
muskegon man
hi i have a 4.3 merc that wen u push the trim buttin the motor pops i have replace spark plugs and the alt on it can any one hlp with the pls and thx
Re: help pls
Ayuh,... Sounds like a short between the trim, 'n the igntion....
Look for pinched wires, chaffing, do the pull, wiggle, tug tests...
More Luck than Skill in something like that...
muskegon man
Re: help pls
hay thx ya my trim dont work going up i have to use the trailer butin to use the trim and i have replace the trim butin and that did not fix the trim prob so i use the trailer one
boattech
Re: help pls
Would need more details to give better advice. But if you have an ignition coil getting week it can cause the engine to stumble when you try to trim the motor. The 12 volts your sending to the trim motor takes alittle power away from the coil causing it to stumble. More details of when the problem happens and what you mean by Popping would help.
