help plz tiller handle
mallardmasher
i need help.. ive looked all over the internet and cant find anything. i have a 1962 johnson 18hp FD16A recently lost alot of power and realized that the little plastic pin in the throttle arm is broken i have no idea what it is called it is after the tiller handle gears and in the throttle arm (plastic piece that engages the throttle arm to turn) anyone know what it is called and were to look for a new one...
HighTrim
Re: help plz tiller handle
Welcome to iboats. Check out laingsoutboards.com, they will have what you are looking for. Good luck.
tashasdaddy
i had to replace mine on my 58 35 hp, it is a dealer part. not expensive. don't know part #.
F_R
You talking about the pin in the bottom end of the vertical shaft? It is part number 304155. It is called a Pin, lever to throttle gear.
tashasdaddy
thanks F_R, superceded number 329197, $3.15 + shipping, ishopmarine.com
