The old outboard is a johnson 5 hp with TN 27 stamped on the side of the power head.
I can't believe it but it hasn't been cranked in about 10 years.
I put fresh gas in it. Opened the valves, pumped the primer and IT CRANKED.
Didn't run very well but it did run.
Now I'm looking for advice on prepping it for use such as lubrication, fuel, technique etc.
Is there a way to run it without having to have it in the lake? I was planning to use one of those clamp on things you hook a garden hose to but I couldn't find the water inlets on the leg?
