HELP! Prop not spinning
The other day when I powered up after fishing I only had half power, if that. Rpm's were normal but the motor would only push the boat so much. When I went in reverse it wouldn't move at all. It also wouldn't stay running after I shut down to check prop. It would die after a few minutes. I don't know if these problems are related, but I noticed today that the prop doesn't spin freely like most do when I turn it with my hand. I can also hear a clicking sound coming from inside of lower unit and the prop won't turn to the left( reverse? ) at all. Any ideas as to what I'm facing here? Any help is greatly appreciated.<br /> <br /> Rocks<br /> P.S. Motor is a '71 85hp Johnson
