Help prop ?
sparkie67
ok i did something not to smart; i took the prop of my motor,and i'm not sure of the order to replace it
25hp mariner 1986.
Re: Help prop ?
Ayuh,.... Welcome Aboard,.... It only "Fits", 1 way....
steelespike
Re: Help prop ?
Service manual indicates a Thrust hub goes on first then the prop followed with a lock nut,sometimes referred to as a jam nut.
It has a nylon insert that keeps it tight. Usually suggested to replace the nut so the nylon is fresh.Nut only tight enough to secure the prop.40-50 ft pounds.
