Fishermark
- Joined
- Oct 19, 2003
- 5,617
This is my new project boat. 1990 Glastron with Volvo Penta SP-A outdrive... I think! Haven't dealt much with Volvo Penta stuff.... I am in the process of removing the outdrive and have run into a couple of snags. (Which is always the case when you boat in salt water! :blue: )
I am at the point where I need to remove the steering pin as described here in the manual:
I was able to successfully remove the two allen bolts holding the pin in, but the pin itself is STUCK. Here's pic of the pin, and then with the bolts I am using as jackbolts.
I have tried heating the helmet and tapping it with a hammer. No joy. I am afraid to put much more pressure on the tow 1/4" bolts as I do not want to snap them off.
Any suggestions or tips? I have never removed one of these and do not know where it typically sticks. Is it in the helmet itself?
