Hi there,
I am trying to refit the shift stick into the gearbox of a 98 DF70. The shop manual refers to a ball, spring and plate but I don't remember seeing any spring or plate when I took it out.
I cannot see how to get the detent ball into the shift cam channel at the same time. Clymer's says "Remove and re-install the shift shaft and/or detent ball as needed" but do you put the ball in first? How then does it sit in the notch?
Any help appreciated
