Re: HELP ! Rotted Engine Mount Stringer
one is bringing the engine stringers back to the proper (same)height after they are removed?
After the motor,+ All is Out of the Way,............<br /><br />Pull some String Lines across at different, Repeatable places,...... <br />Using Plumb Lines or Tape Measures,... Or Whatever's nessessary,... <br />Plot Exactly Where they are Now,....... Draw a Picture,... Take some Pictures,.....<br /><br />Boats are Not Square,...... Heck,.. Most of them Aren't even Symmetrical,..........
<br />Do All your measuring from the "Keel Line",+ the "Transom"........<br />The String Line is Your Friend,....... Use It,......<br />Just make Sure to use Attachment Points that'll Still be Usable After you've Removed All the Bad Parts...........<br />As long at the String Lines are Repeatable you can get Everything Exactly Where it Belongs..............
<br />
two: Engine disconnect! I have the manual but it looks like a pain in the a**.
You've Got to be Kidding,.......... Have you ever Tried to pull the motor out of a Newer(Anything After 1968) Car,...???...... <br /><br />1,... Pull the Drive,...... <br />6 5/8ths" Nuts,..... 2 9/16ths Nuts on the Rams,......<br />Pull It Off,....... Careful,.. It's about 80lbs.......<br />2,... The Motor Mounts,... <br />2 big Bolts in Behind the motor, at the Transom Assembly,... Then the 2 just like the 2 that Fell Out,....<br />Disconnect a couple of Hoses,.... A Couple more Wires,... And the Big Cannon Plug,......<br />Pull the Motor,..... She's Yours..................................
<br /><br />I could have it sitting on the Ground in Under an Hour,...... Here in My Driveway,.........
