I have a 1967, 60 H.P., V4, Evinrude sportfour. Model 60753A serial E05224. <br /> A bit of history to help understand the prob. I am the third owner and know the person that bought it new, he unfortunatly let it sit for years and it suffered. My father (the second owner) and i have put a great deal of work starting with a compression test which it past with flying colors (water pump, points, condenser, fuel lines and pump, filter, coil, plugs and wires, rotor all new) It runs like a dream, just not quickly or at a high rpm. When i throttle up its as if the engine bogs down. There's just no power. I can choke the engine at anytime and there is no difference in it. As far as i know it should kill the engine , but like i said it doesnt change anything
.I'm wondering if i pull the carbs and clean them all up really good if that could help the problem? Also i'm not sure what the reed valve does. Would that contribute to my power loss? Or am i not even in the right direction? Please experts show the the way! I appreciate any help.
