Help setting timing on 1970 1150
hoosiercaver1
I have read alot of the posts on link and sync on the tower o power. I want to set the timing like it says, but I do not see a timing mark, or a timing gauge on the flywheel to line it up with. I also wonder if a normal automotive timing light will work, or do I need a marine two stroke one. Any info on where to start would be great. My engine runs ok, but doesn't start well after its ran and sat for an hour. I put a used distributor on it cause the po screwd up the old one and I want to make sure it is set right. Thanks John
hoosiercaver1
Re: Help setting timing on 1970 1150
I would also like to know what kinda tach I will need. My old one wouldn't work on a 6 cyl do I need to find a new one.
Chris1956
Tachs normally work on most merc models. Your older motor probably has the tach wire connected to the switchbox. More modern tachs use the stator to drive them.
