snowman51789
- Joined
- Sep 8, 2010
- 136
lately every so often ive been noticeing issues with shifting, first sighn was it wouldnt go into reverse untill i moved the shifter back and for a few time. went home, checked the adjustment, made very minor adjustments, then i started noticing that when i would push the throttle into forward, it wouldnt go into gears untill i pushed the throttle to the point just before the motor started revving up, and when i put it in reverse, it gose into gear almost as soon as the throttle is moved out of neutrol. im assuming i need new shift cables but im hoping somebody could tell me whitch one i need, im a little short on cash and am trying to avoid doing them both right now. or is there an adjustment that i could make?
ive never worked with shift cables before other than makeing the adjustments that are in the manual so if it sounds like i may have overlooked something, its probley because i did, anyadvise would be a big help.
thanks
Dave
thanks
Dave
