hraustin3794
- Joined
- Jul 2, 2010
- 3
A friend just gave me a 1962 3HP Evinrude Lightwin, was his grandfather's & looks to be in good shape. He said his grandpa took it to a mechanic and had everything checked out & running about 4-5 years ago and then stored it in the shed. The gas tank is bone dry...they probably burnt the gas out of it and emptied it. I would like to fire it up & put on jon boat.
1?] Should I mix up gas and swish it around in the tank & empty a couple of times for any loose debris?
2?] If it fires up, should I watch closely to see that the impeller is spitting out water....main ques, would the impeller probably be good to go if it works or should it definitely be replaced assuming dry rot.... don't have much money.
3?] If it should be replaced, where can I order one....and is it easy to do...I'm pretty handy and changed one on a 40 hp before.?
4?] Any other tips or things to do or look out for in getting it back to service?
Just trying to get out there and catch a fish : ) Thx in advance for your help!
