rustyoletoy
- Joined
- Aug 3, 2004
- 11
I have a 25hp Evinrude, rope start and manual primer. I have been having a headache starting this motor while cold (it floods) and after going through everything, the motor is nicely dialed in now but I still the same problem starting while cold. <br /> I'm now figuring that my start-up procedure with the primer is wrong. How many times should I pump it? Should it be pushed all the way in when I try to start (while I'm pulling like mad it seems to start more often in this spot than any other location) or left at some other spot? <br /> The little drawing beside the primer knob shows all the way in and a little 'no spark' drawing, half way out and then all the way out with a 'spark' drawing.<br /> Help!!<br /><br /> Sean
