Help stuck on lake. Trim stuck down. Cant trailer boat iler
Shark_bait99
Help the trim switch in my four Winns sundowner 225 with a Volvo 5.7 gi 2004 does not respond. Stuck in full down so I cannot trailer it.
Any idea where the fuse is? The trim switch is attached to throttle. Manual says fuses are on trim pump mount but can't get to it bc it's behind engine. Ideas pls. Quickly. Engine starts and runs fine as do all electronics. Trim was working 10 min ago.
Don S
Re: Help stuck on lake. Trim stuck down. Cant trailer boat iler
Disconnect the trim pump motor connector in the 2 wires on the trim pump motor.
Jumper the blue wire to the positive terminal on your battery, the green to the negative terminal. If the motor works, it will come up.
If not, disconnect the trim rams from the back of the drive and lift by hand.
Shark_bait99
You're the man don. Was time 10a fuse next to the pump. THANK YOU!
