Customline
- Joined
- Nov 13, 2001
- 10
Hi,<br />I have a 50's (?) Evinrude Fleetwin 7.5. Last weekend we swamped the boat and the motor was submerged. Following the owners manual here is what I have done so far.<br /><br />- removed and cleaned carb, fuel bowl<br />- removed plugs, cleaned and dried<br />- with manifold down, cycled motor and let water run out.<br />- removed starter and let points dry out<br />- with compressor and air hose, air dried ignition components<br />- squirt oil in the cylinders and rotated engine. repeated several times.<br /><br />At this point I have no spark. Last night I sprayed the ignition parts with WD40 to dissipate the water. Have not checked for spark again, but will tonight. <br /><br />Unless anyone has any other ideas, I am going to take the flywheel off and attempt to dry the ignition parts out further. How do I get the flywheel off. I loosened the crankshaft nut but cant seem to get the flywheel off. I have a parts motor and as a last resort I could switch the magneto, flyweel and ignition. If I can only get the flyweel off. Sorry for the long post. Anyone got any suggestions?<br /><br />Gratefully - Doug
