Hi there,
Having some problems with my 1978 omc 120hp inboard. I think that there is a problem with the water cooled intake or exhaust manifold because they have changed everything else. The problem starts after about 11 min of running time the motor stops it as it has begun to run real lean in the middle of the lake. Could there be a problem with the intake and the exhaust manifold could it be cracked which is causing the mixture to become to lean with not enough fuel? The carb has been checked and is running good on another vehicle. Would love to have this thing running before the season ends. We have put new fuel pump, + elec pump ahead of it and fuel is under pressure. redid all the electrical, plugs,wiring,points everything.
