IT WON'T GO AWAY???!!!<br />This is the same noise I've had from the beginning. It sounds like a loose pushrod. I adjusted them .... the noise remained.<br />So I replaced all pushrods and hydraulic lifters. (Even tho none of the rods were bent .... and none of the rods or lifters showed ANY signs of wear.)<br />Previous owner mentioned that the noise always was there but it quiets down after a bit of running.<br />I AM NOT going out into the Gulf of Mexico with that noise threatening my engine.<br />I ran Mystery Oil thru the system to clean out crud in the oil system. Then drained it and put in new 20-50 weight Valvoline. Put in new plugs.<br />Set the timing to 10 degrees before TDC .... <br />Used the "dry method" (engine not running) to get the pushrods tightened down precisely and tightened the rocker arm nut down 3/4 of a turn after the pushrod was tight (at lash?????).<br />No luck.<br />Two mechanics have listened and agreed it is coming from the top, front of the engine and it sounded like a loose pushrod.????????????????<br />Jeez...... <br />One old shade-tree mechanic suggested it was "spark plug knock' from using 87 octane gas instead of 89 octane. Would it make that loud of a noise??????? I had some 87 octane gas in the tank but now have added some Octane Booster and will see if the knock gets quieter. <br />But I don't think that is the problem. The noise is too loud????<br />I have been after this noise for over a month - out there in 90 degree heat - trying everything suggested and the noise is still there????<br />PUHLEEZ HELP!<br />Skip
