Fisher Man
- Joined
- Jun 2, 2009
- 5
5.7 Gsi PEFS throttle body injection
i can put around all i want but seemingly just fine but as soon is you give it gas and it gets up to 3000rpm it will sputter or miss... and then recovers... then sputters and alittle backfire but not always backfire then it will drop
maybe 2-300 rpm and make its way back up to around 3100 or 3200 rpm and repeats the said process...
so i put in a new cap and rotor and wires and still same problem only difference is that i get another 8 knots out of my 3000 rpm. but same problem.
other symptoms are:
blacker exhause at idle and lower rpm
thats really it... im sure its getting too much gas and the new cap n' rotor just helped burn the exess gas...
Throttle Body ? what do i do with it? that it?
FI
other symptoms are:
FI
