HELP throttle broken Four Winns 1991
4WINNSMAUI
I need help how can I order parts for a 1991 Four Winns 25' Sundowner??? Throttle is stuck and will not go in forward or reverse but can shift from engine manually. I need to replace throttle cable/ linkage system????
Re: HELP throttle broken Four Winns 1991
Ayuh,... Both controllers, 'n cables are readily available through the aftermarket,...
Probably right here at iboats megamall...
