steelespike
- Joined
- Apr 26, 2002
- 19,069
Can anyone tell me what these propellers fit or where to find out.
Michigan aluminum 3 blade outboard marked PJ 32 10 1/2" X 12",straight bore with 2 grooves 180 degrees apart.Shear pin through the top.No through hub exhaust appears like OMC?
3 blade Michigan bronze outboard propeller.number appears to be S M C 655.looks like 10 inch diameter.Bore is similar to the the PJ 32 but bigger and longer.Shear pin through the top.No other markings.No through hub.
Two blade bronze outboard C.1920s? 8" X 8" appears to be 9/16 straight bore 1 1/8" long. Shear pin under hub ,1" X 1/4. Number on hub 100745 number under hub 110576? difficult to read.
3 blade Federal Mogul Bronze inboard. Under hub marked C-C L F 5-1-34.I assume first is counter clockwise second maybe a date code.Taper bore appears to,be 15/16" numbers on hub are 7530. 10" diameter.No pitch indicated hoping maybe can find that out.Thanks
