help to identify the year mariner
cuenta619
help to identify the year mariner 25hp.
the tag is missing and only see this serial number in the block ..0g873327
and another question about this motor have problem to start I check the carb. And I not see the choke plate when push the key hear a click. .
flyingscott
looks like a 1996 model or up. There is no choke on that motor only has a primer. The small cylinder on top of the carb.
cuenta619
Thank guy's .. now I just have to learn more about the electric primer any way to make primer manual. ???
cuenta619
Your serial number 0G873327 turns into model number 7025312HD which makes it a 1999 model year for your 25HP - EL MARINER engine...http://ww2.iboats.com/MARINER-25-HP-25-MARATHON-1999-2004/dm/view_id.1696167
thank . I order the carb rebuild kit and fit perfect .
in the pic. the idle screw is the A or is the C red arrow ??
when I move the C screw the rpm rise . I think he idle screw is the A arrow ..
or botch screw are idle adjust.
https://imgur.com/a/iyMBigJ
