Help. Transmission oil? 1987 Merc 7.4L GM-454 V-8 ?
WishGranted
Hey guys.i don’t have the Merc owners manual and i had to replace the oil to my transmissions and Im getting conflicting recommendations for what to use. It’s 1987 - engine serial numbers B793144 and B793005.
I’m stuck at the dock and don’t want to do this twice by using the wrong one. Should I just use HD 30?
Grub54891
Transmission? Is it an IO or inboard? What color of fluI’d did you remove? What brand of transmission if an inboard?
WishGranted
Inboard. Oil hasn’t been changed for the 7 years I’ve owned the boat. And the oil wasn’t black but a rich brown. (And not red).
Not sure if the transmission. But connects to a Walter V-drive if that’s a clue.
back in 1987, every fluid on your boat would most likely be SAE 30. it will be in the steering system, the trim tabs, the motors, and the drives.
