jimbobcooter
- Joined
- Feb 27, 2012
- 78
So I noticed I had some water in the lower unit/gearcase of my Evinrude E120TLERC so I drained it and added a small amount of pressure. Then checking with soapy water I noticed no leaks except for when the driveshaft was manipulated side to side air would shoot out. Purchased a new drive shaft bearing assembly with new seal and installed. Ran the motor for about 5hrs and again I have water in the gearcase...not a lot that I can tell but definitely milky (using Evinrude HPF).
So I took it o the shop for a professional pressure/vac test and they siad nothing is wrong...no issues. Refilled with oil and now want .75 hrs of labor and $10+ for oil =$78
If pressure/vac test are perfect how am I getting water in lower unit?
Previous trip to the shop was excessive water pressure not allowing engine to get up to temp with was resolved by installing an oversized gourmet to get more water out the overflow.
I will handle the shop and their ridiculous request for labor cost this afternoon, but I want to fix my boat...any help is appreciated.
