s2gots
- Joined
- Oct 2, 2007
- 112
Hey guys...I took my boat out sunday to the lake for some fishing for the first time in at least 6 months...yes, I know I know, its been too long. Anyway, Ive never had problems with water getting in the bilge before. After I put her in the water, she fired up fine, tied up at the dock for about 10 minutes and let her idle a bit as I waited for someone else to arrive( it wasent busy,and no one was there launching or retrieving, so I wasent holding up anybody!!) Checked her out before we un-tied, and bilge was dry as a bone. BTW, The speed limit at the lake is 10 mph. Just as a precaution, I checked the bilge every so often to make sure there were no problems/leaks, and for the first 4 hours, all is good-well, except we havent caught any fish, well keepers...
I stopped at a shallow area to fish for a bit, shut her down and started fishing....I didnt anchor up because we didnt stay in one spot for too long... so I was getting a bit too close for comfort to shore, so I fired her up, and started backing up and turning to one side, I was barely out of idle and moving slowly....my buddy yells, "Hey be careful its super shall...." before he could finish the word shallow, the prop hits ground and engine cuts out. I raise the outdrive a bit, fire up again, and proceed to move out of the shallows with no ill effects. About an hour later, I hear the bilge pump pumping out water. I keep it running and open the bilge up, and see about 2 inches of water..its barelly enough to turn on the float at the bilge pump as the water moves back and forth...no water is coming out of the engine block, and I cant see any wet areas except down at the bottom of the bilge area.
Id doesent seem like a bad leak. After the mishap, I stayed on the lake for another 2 hours, and the pump came on once for a couple seconds. Once I got the boat out of the water, there was minimal damage to the prop, the plug was in, the boat didnt bottom out, only the prob touched bottom.....I didnt see anything out of place on the outdrive.. Any suggestins on where the water might be coming in from?
88 four winns horizon 200 Cobra outdrive GM 350 small block
TIA
S2gots
TIA
S2gots
