Re: HELP! Water pump troubles on '81 Merc 115 inline 6
As Clams says, it should lift straight off but sometimes a bit of corrosion builds up on the driveshaft just above the impeller. I had a 95 model 200hp merc with the same problem a couple of weeks ago. <br />Be careful if you are going to cut it off or use some sand paper to take the obstruction off. I used a strip of coarse emery cloth and it took about 10 mins.<br /><br />Cheers,<br /><br />Nicholas<br />Bayside Marine P/L
