Re: help which motor 78 2 HP or 50's 3 HP
I agree with Scoop. If the older 3hp has been well maintained and is in overall good shape, there's no reason it can't be a good motor for years to come. Basic maintenance parts such as waterpump impeller, carb kits, magneto parts are all readily available, fairly cheaply. The 3hp is a MUCH smoother running motor (advantage of two cylinders over one) and doesn't weigh a whole lot more (only 32 lbs.). Both motors use the same ignition type (3hp has two of everything, 2hp has one) so that's a push. Both motors use the same basic carb design - another push. Again, if the 3hp is in really good shape, I'd go for that....<br />- Scott
