Help Wiring Outboard Ignition Switch
sasto
I will try to make this simple.
I have a 6 wire ign. switch for a 70hp Merc OB. Colors are: red, black/yellow, purple, black, yellow/red, and yellow/black.
My choices are: ignition circuit, solenoid, choke, battery, magneto, ground.
I know 4 of them from wiring diesel motors. Help for all of them is appreciated. Thanks!
Silvertip
Yellow/Black = choke = "C" terminal on switch
Purple = Accessories (instruments power) = "I" terminal on switch
Black/Yellow = magneto = "M" terminal on switch
Black = ground = "M" terminal on switch
Yellow/Red = Starter Solenoid = "S" terminal on switch
Red = Battery positive 12 volts = "B" terminal on switch
There are two "M" (magneto terminals because the switch connects those two terminals in the OFF position to short the ignition to ground. This is how a magneto system is shut down.
sasto
Thanks! I knew I could count on you, Silvertip. The engine is now running,
gm280
And to add to that "M" terminal info, those same wires go to the kill switch as well to turn off the engine if you fall overboard...
