Re-Assembling this motor and I have 1 wire I don't have a clear picture as to where it belongs.<br />The boat is a '77 Sea Ray (SRV 197) w/ 5 litre Chevy/Mercruiser (Alpha 1).<br /><br />It's the purple wire coming out of the wiring harness (w/ the 2 red wires). Looks like it's to be attached to the distibuter w/ the black wire (black wire w/ the yellow connectors is a jumper that's going from the distributer to the negative side of the coil).<br />Thoughts on the purple?<br />Does it go to the distributer terminal w/ the black wire?<br />Not any other options I can see given the limited length of the wire?<br />Tachometer lead I assume?<br />
