Hi, I'm in the process of trying to remove the lower leg on a 1972 Johnson 65hp to check impeller condition. Dropped the oil and was squeeky clean just a couple of tiny shavings on plug screw, removed 6 bolts and with a few light taps the leg drops but only a few inches and goes no further, can i completely remove the leg to have full access to the water pump housing. Whilst writing this I have had a flash thought thinking maybe the solenoid wires are whats stopping the leg dropping, but while trying to remove leg earlier the wires never tightened up of had any sort of tension. So do i remove the wires from the top of the engine to be able to drop the leg off completely?
Also noticed a rubber seal next to water pump housing which upper part of leg slides into, seems quite perished. Is there a quick fix for this like running a good bead of silicone around it?
Appriciate the feed back as I bought a downloadable service manual but it's so difficult to read and understand and has limited pictures included.
Thanks
Thanks
