daverowlands
- Joined
- Aug 29, 2007
- 24
Hi all, Have a 1996 3cyl 35hp. Carbs and timing set up recently by a local workshop, cylinders all firing blue on the spark test, starts from cold with only a couple of revoulutions of the flywheel and ticks over perfectly. But kick it into gear and as soon as load comes on engine stops? Service guy rekons could be a leak into crankcase and he says its going to be $1000 if this is the case. Any help or a test of how to find out if there is a leak between cylinders would be good
thanks
thanks
