Re: help with 69 merc
Hi Ratt,<br /> Great old motors - I've got a '69 with a tiller that I rebuilt last winter and have been running a bit this season.<br /> For starters, you'll have to remove the trim tab to access the rear lower unit stud. Access the trim tab bolt with a 5/16" (I think) Allen wrench coming down through the hold in the top of the leg. Before removing the tab, mark it's position. Remove the nut underneath, the one forward above the prop, and the two on either side above the cavitation plate. The unit should drop down.<br /> On top of the unit you'll see the water pump housing - the base contains the upper seal. It's likely that your motor is leaking at that seal, as often the carbon steel shafts would rust at that point. I've fixed several shafts using JB Weld to fill the pits and have had good success so far...<br />- Scott
