HI ALL,<br /> i don't know what to make of this. when idling along and (sometimes at full throttle)then try to speed up it wants to buck like a bronco. the RPM's goes up and down like a yoo-yoo. i can cut it off and sit for awhile and it does fine. i have had the carb apart countless times...clean as a pin! i felt the primer bulb when it does this and it tight. maybe float sticking? it seems not bind at all when i have the carb off the motor. any help would be greatly appreciated. thanks, LIKEAROCK
